I've had cases where ADCAD_ZZ had layers emdedded so they could not be
deleted. In some cases it really is needed to delete the corrupted block.
"Joe Bouza" wrote in message
news:5273906@discussion.autodesk.com...
Hi John I used, in the past, RENAME block to "junk" and LDT will ignore it.
Joe
"John Mayo" wrote in message
news:5273880@discussion.autodesk.com...
I would love to see it Jeff.
No locked layers.
John
"Jeff Mishler" wrote in message
news:5273867@discussion.autodesk.com...
Hi John,
Thanks for the explanation, it makes more sense now. I seem to recall seeing
this problem when the block was placed on a layer that got locked. Since it
was locked, no changes could be made to the attributes which caused the
types of issues you show.
If you really want it removed....... I've got a lisp somewhere that does
this. I'll go try to locate it while you check for locked layers.....
news:5273813@discussion.autodesk.com...
Hello Jeff,
< snipped error stuff >
