AutoCAD Land Desktop (Read Only)
Message 1 of 27
479 Views, 26 Replies
Acad_ZZ
How do I purge this beast??
John
26 REPLIES 26
Message 21 of 27
My son also uses this PC to play memory match game on PBSKids.com. There is
no personal email or any other perssonal data on it to help protect him in
case he flips the thing on when I'm not watching. Parenting is my primary
focus in life right now. I want to produce somone better than myself 🙂
John
"abyss" wrote in message
news:5273989@discussion.autodesk.com...
Moonlighting as well I see.
It's just my dry humor & hatred for spam, spam, spam.
John
"Don Reichle" wrote in message
news:5273988@discussion.autodesk.com...
OK Mr. Mayo - I hafta ask re. the "abyss"?
@ home?
My imagination runneth wilde!
Your poor spouse/"significant other"!
:-o
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
LDT/CD-2K4
AMD Athlon 64 X2 Dual-Core 3800+ 2.01GHz
XP-Pro 32bit SP2
2GB RAM
Dual WD800JD Hard Drives - 149GB Nvidia Stripe
Nvidia Quadro FX 1300 128MB
Dual ViewSonic 19-inch VA902b monitors
"The only Constant is Change".
news:5273960@discussion.autodesk.com...
It's power training. 4-days, 4-classes per day. Excellent instructors.
Excellent price.
JohnM @ Home, unwinding after a hectic week. I got out a 10 car parking lot
expansion that is taking 4 plan sheets to get approved. I can get a house
built w/ a one sheet plan...Gotta luv g'vment.
"Joe Bouza" wrote in message
news:5273913@discussion.autodesk.com...
Holy cow .. I just ran it up the flagpole and got a "gimmie the details"
I'll keep ya posted.
Joe
news:5273912@discussion.autodesk.com...
Thanks, I remembered we had to do that to "migrate" S8 projects to R14 ( tip
from Microdesk in NH ...good service people).
Anyway, I must be showing my age going that far back
Happy to help. I have not built up the courage to ask for the Vegas trip -
sounds like alot of fun.
Joe
"John Mayo" wrote in message
news:5273895@discussion.autodesk.com...
You always chime in with good stuff Joe.
Thanks.
news:5273906@discussion.autodesk.com...
Hi John I used, in the past, RENAME block to "junk" and LDT will ignore it.
Joe
news:5273880@discussion.autodesk.com...
I would love to see it Jeff.
No locked layers.
John
"Jeff Mishler" wrote in message
news:5273867@discussion.autodesk.com...
Hi John,
Thanks for the explanation, it makes more sense now. I seem to recall seeing
this problem when the block was placed on a layer that got locked. Since it
was locked, no changes could be made to the attributes which caused the
types of issues you show.
If you really want it removed....... I've got a lisp somewhere that does
this. I'll go try to locate it while you check for locked layers.....
news:5273813@discussion.autodesk.com...
Hello Jeff,
< snipped error stuff >
Message 22 of 27
Thank you Jeff
Joe
news:5273910@discussion.autodesk.com...
Here ya go, although I think Joe's idea is pretty clever.......
(defun c:kill-AdCadd_ZZ (/ ctr blks)
(vl-load-com)
(if (tblsearch "BLOCK" "ADCADD_ZZ")
(progn
(setq ctr 0)
(vlax-for blk (setq blks (vla-get-blocks
(vla-get-activedocument
(vlax-get-acad-object)
(vlax-for ent blk
(if (and (vlax-property-available-p ent 'hasattributes)
(eq (strcase (vla-get-name ent)) "ADCADD_ZZ")
(progn
(vla-delete ent)
(setq ctr (1+ ctr))
(vl-catch-all-apply '(lambda ()
(vla-delete (vla-item blks "ADCADD_ZZ"))
(princ
(strcat "\nDeleted " (itoa ctr) " instances of ADCADD_ZZ! ")
(princ "\nADCADD_ZZ not found in this drawing....")
(princ)
No locked layers.
John
Message 23 of 27
Thanks again Jeff.
I put it to good use on all of out templates.
Blocks next.
John
news:5273875@discussion.autodesk.com...
Yes and No........ there are no invisible blocks such as this, but there are
a ton of Custom Objects, Styles and Dictionary entries that hold far more
data than Adcadd_ZZ ever thought of 😉
news:5273827@discussion.autodesk.com...
Is there a C3D component such as this also Jeff?
Message 24 of 27
Joe,
You might want to check out the "Power Track" for Civil 3D. We tried to make
a series of classes (in order) that went start to finish and gave a nice
over view of Civil 3D.
Sign up now, the classes are starting to fill up!
Peter
Message 25 of 27
You can select this block using the quick select tool. Select block
references with name=ADCADD_ZZ and it will select it and you can then delete
it. You will have to re-run the quick select for each layout. This may not
be elegant but it works. Quick select is a handy way to select ghost
objects.
news:5273757@discussion.autodesk.com...
John
Message 26 of 27
Another good tip Neil.
John
"neilw" wrote in message
news:5301466@discussion.autodesk.com...
objects.
John
Message 27 of 27
I've had cases where ADCAD_ZZ had layers emdedded so they could not be
deleted. In some cases it really is needed to delete the corrupted block.
Joe
No locked layers.
John
Hi John,
Hello Jeff,
