Aaron thanks for the reminder re. PurgeIDs.
I'm going to have to hunt down the copy I have put somewhere?
Or just Google it;
http://tinyurl.com/oqbqq
It's the Zip file attached to James Maeding's post.
HTH
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
LDT/CD-2K4
AMD Athlon 64 X2 Dual 2.01GHz
XPPro 32bit SP2
2GB RAM
Dual WD800JD Hard Drives - 149GB Nvidia Stripe
Nvidia Quadro FX 1300 128MB
Dual ViewSonic 19-inch VA902b monitors
Aaron Lance wrote:
> It's not the ram. LDT 2006 is just slow.
> I think Autodesk's company line is "Why don't you have the newest fastest
> computer available?" I do, and 2GB of RAM, and the latest patches, and the
> lastest drivers, and a gigabit network. I also keep the drawings small
> (typically less than 1MB), although I do multitask a lot (usually
> outlook/excel/vba/Land(2-4 sessions)/winamp). After opening the first
> session, the rest are faster, but I've found that if I'm working with
> anything calculation intensive, it's quicker to fire up 2000...
> You can turn off all the new options that have been added recently (object
> highlighting, dynamic input, etc.) and it'll still be slower than 2000. In
> particular, menu loading, the CUI editor and layer dialog just crawl. They
> worked just fine before. If it isn't broke... what happened?
> BTW, don't use SAVEAS to save back to 2000. You have to use a feature
> called "export to AutoCAD"... or type in _AECCEXPORTTOAUTOCAD2000. It's in
> the Land Desktop File menu, not the AutoCAD file menu. That command is the
> only reliable way I know of to remove the "Architectural Desktop" errors
> you're getting.
> If you're going back and forth between 2000/2004/2006, you'll also want to
> locate and use a program called PurgeIDs (I think I found it in one of these
> newsgroups, but you can google it), to get rid of AppIDs that get imported
> into r2000 versions. The appids spread like a virus from drawing to drawing
> by xrefing. When we started using PurgeIDs, our typical drawing had
> ballooned by 1.5MB each, because of about 50,000 unused APPIDs,... After
> using PurgeIDS, the drawings were reduced to their normal size of about
> 100-200KB... and opened a lot faster without the ADT errors. The program
> has some quirks, but it does the job.
> Good luck
> - Aaron Lance
> wrote in message news:5217304@discussion.autodesk.com...
> I realize that the ram may have something to do with this. I'll have to
> watch this after I install the SP's on Monday. I just thought there might
> be a quick fix for today. Otherwise what we opened up in 2006 was saved
> back to 2000 and now when he opens we keep on getting that Arch. Desktop
> object enabler message for some reason. Even though I installed the 2004 OE
> for 2000i.
> Thanks for the help though.
> Heidi
