You probably need to do a complete uninstall and reinstall of Land Desktop.
In order to do this, you need to uninstall the program, then, go to
Start-->Run. At the entry line, type REGEDIT.EXE. This will bring up the
system registry editor. Before editing anything, back up your registry to
your desktop, or to a removable flash drive, etc. Then, do a search for
anything like Autodesk, Autocad and Land Desktop. Delete those entries. It
may take more than one go through to get them all. Once you've done that,
save the registry and reboot your computer. Then reinstall Land Desktop.
Everything should work smoothly after that.
Dennis Hyman (aspiring PLS)
Cad Tech. - Survey Dept.
Stock & Associates Consulting Engineers
Chesterfield, Missouri
LDD 2004, Civil, Survey, Map
2.4 Ghz P4, 512 MB RAM
GeForce 4 MX 440 Graphics Card
wrote in message news:5740473@discussion.autodesk.com...
Hello I have been having this issue for about a wek and cannot figure it
out. I installed Civil 3D 2008 to mess around with and begin learning the
processes, and then uninstalled it about a week after when it was having
some problems. Now that I have uninstalled Civil 3D 2008 my land Desktop
2006 does not want to startup. I am getting an error at startup "Exception
in c:\Program Files\Autodesk Land Desktop 2006\ ACMapWorkspace.arx ARX
Command". I have tried a repair install and two complete reinatalls and
installed service packs. I have browsed the topics and cannot find any
answers. Anybody have any suggestions?
