AutoCAD Freestyle (Read Only)
The Quick Access Toolbar in Freestyle is missing
0 REPLIES 0
Message 1 of 1
avto
517 Views, 0 Replies
After updating Freestyle from Technology Preview you may not see the Quick Access Toolbar.
To restore the Quick Access Toolbar please follow steps below:
1.Close Freestyle
2.Open Windows Explorer
3.Based on your operating system navigate to:
Windows 7 or Vista
C:\Users\your_user_name\AppData\Roaming\Autodesk\AutoCAD Freestyle\R1\enu\Support\Profiles\Unnamed Profile
Windows XP
C:\Documents and Settings\ your_user_name\Application Data\Autodesk\AutoCAD Freestyle\R1
If AppData or Application Data is not visible you will need to enable “Show hidden files and folders” in the Folder Options of Windows Explorer. To enable Show hidden files and folders:
on Windows 7:
Go to Start > Search > type "hidden files" with our quotes in the search dialog box and hit key.
Folder Options window opens, please select 'Show hidden files, folders, and drives' radio button
Windows Vista
Go to Start > Control Panel > Folder Options.
On the View tab, under Hidden files and folders, click Show hidden files and folders.
Windows XP:
Go to Start > Control Panel > Appearance and Themes, and click Folder Options.
4.Rename profile.aws to profileORG.aws
5.Launch Freestyle
Note: This is similar to a secondary install and will restore all the Freestyle UI in Freestyle to its default state.
Thank you for your interest in Freestyle.
Avto Chachava, Autodesk Product Support
Avto Chachava
Autodesk, Inc.
0 REPLIES 0
