AutoCAD Freestyle
New Member
drewhinkle
Message 1 of 3 (1,434 Views)
Mirroring Text
1434 Views, 2 Replies
01-24-2011 11:32 AM
I am trying to mirror text.  Specifically, turning an "S" into a backwards S.  When selecting the character, 8 nodes appear at the 4 corners:  4 inner and 4 outer nodes to be exact.  If you click & hold one of the outer/square nodes, you can drag it horizontally, creating a mirror image of the character.  However, once you release the node the character returns to normal.  How do you get around this and create a mirror image?  It is obvious that the function resides within the software code, but I am unable to find the command to do so.
To mirror text:
1.select your text
2.right click on it and select ‘Create Symbol from Selection’
3.right click again and select Flip > Flip Horizontal
4.once you mirrored your text, delete the symbol you created in step 2 form Symbol Libraries > Custom Symbols
Hope this helps.
Product Support
avto
Message 2 of 3 (1,432 Views)
Re: Mirroring Text
01-24-2011 12:40 PM in reply to: drewhinkle
To mirror text:
1.select your text
Hope this helps.
Avto Chachava
Autodesk Product Support
New Member
drewhinkle
Message 3 of 3 (1,429 Views)
Re: Mirroring Text
01-24-2011 01:04 PM in reply to: avto
Thanks for the easy, prompt, and thorough response!
