I have opened a separate thread specifically for Error 1603, where we can discusses possible workarounds of the issue
http://forums.autodesk.com/t5/AutoCAD-Freestyle/Installation-of-AutoCAD-Freestyle-exit-with-code-160...
Avto Chachava,
Autodesk Product Support
After installation I launched program and received this error immediately:
FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at c86819h
Then prompted to save changes, even though nothing has been done in program.
The possible cause of this error is inadequate graphics card for Freestyle.
Please try the suggestion provides in the post below.
http://forums.autodesk.com/t5/AutoCAD-Freestyle/Freestyle-crashes-at-start-up/td-p/2692096
I completed the instructions that were posted about changing the target to - "C:\Program Files\Autodesk\AutoCAD Freestyle\acadfs.exe" /nohardware - and still have the same error message pop up when trying to open program.
Could you provide an additional solution.
Just to keep Freestyle installation and start up errors easy to search, I opened a new thread against the error message FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at c86819h
This is the error I got in the error log when trying to install:
2010/6/14:12:58:37 foden_c CH3489 === Setup started on CH3489 by foden_c ===
2010/6/14:12:58:37 foden_c CH3489 Download Eula.
2010/6/14:12:58:38 foden_c CH3489 Download Pit.
2010/6/14:12:58:44 foden_c CH3489 Download Component DirectX 10.0 runtime.
2010/6/14:12:58:48 foden_c CH3489 Download Component AutoCAD Freestyle.
2010/6/14:12:58:48 foden_c CH3489 Installing Component DirectX 10.0 runtime.
2010/6/14:12:58:49 foden_c CH3489 Installation of DirectX 10.0 runtime exit with code -15.
2010/6/14:12:58:51 foden_c CH3489 Installation Error: Setup was cancelled
Please try disabling your Internet security application and antivirus, and install Freestyle again.
Sorry, I produced a new message. I am having problems installing Freestyle. I am attaching the error file.
Thank you Avto....it was a security issue which is now resolved and the software installed.
Cheers,
Cara
Unable to install trial version of AutoCad Freestyle. One of the error messages states: “Installation of autocad freestyle exit with code 1603”
Could you please try suggestions offered in the post below and then update that post with your results
piercecotter, I updated your post regarding Error 1310. Error writing to file: C:\Config.Msi\5101112.rbf
http://forums.autodesk.com/t5/AutoCAD-Freestyle/Freestyle-Installation-Failure/td-p/2697234
I just tried to install AUTODesk Freestyle (free trial) and got a diaglog box stating the installation was not successful with an exit code 1603. What must I do to proceed?
Installation error, full test follows:
2010/6/21:14:22:01 Ann Schilling ANN-GARY === Setup started on ANN-GARY by Ann Schilling ===
2010/6/21:14:22:02 Ann Schilling ANN-GARY Download Eula.
2010/6/21:14:22:02 Ann Schilling ANN-GARY Download Pit.
2010/6/21:14:22:12 Ann Schilling ANN-GARY Download Component AutoCAD Freestyle.
2010/6/21:14:24:27 Ann Schilling ANN-GARY Installing Component AutoCAD Freestyle.
2010/6/21:14:26:54 Ann Schilling ANN-GARY Installation of AutoCAD Freestyle exit with code 1603.
Please try suggestions discussed in the following tread
I purchased a copy of Free Style this morning and am not able to down load. Following is from the error log:
07/29/10,11:41:36] ***ERROR EVENT*** : Custom Action Failure:Action ended 11:41:36: InstallFinalize. Return value 3..
[07/29/10,11:41:36] ***ERROR EVENT*** : See Windows Install log for details.
[07/29/10,11:41:42] ***ERROR EVENT*** : Custom Action Failure:Action ended 11:41:42: INSTALL. Return value 3..
[07/29/10,11:41:42] ***ERROR EVENT*** : See Windows Install log for details.
Any ideas?
Dave
I got a message that said
"Your installation of AutoCAD Freestyle was not successful.
Please visit the Freestyle support web page for more information."
What I think is the error log file is attached.
Please help.
Hi Dave,
There is a freestylesetup.log that is created in your temp folder that will have some clues. There is a link on the failure dialog to give you quick access to where the log file is, can you either attach it or else please email it to me?
Michael Nauman, AutoCAD Freestyle TD Lead
