AutoCAD Freestyle
Member
tendring
Message 1 of 5 (2,959 Views)
can not load plcfmgr.dll
2959 Views, 4 Replies
01-12-2011 08:35 AM
Have down loaded three times the trial version of AutoCAD Freestyle the last attempt with firewall and AV off however the same message is given before the programme closes via a polite message the we have a problem!
Product Support
avto
Message 2 of 5 (2,946 Views)
Re: can not load plcfmgr.dll
01-13-2011 10:55 AM in reply to: tendring
Typically this error occurs when the Windows dll prntvpt.dll is missing or corrupt.
The following hotfix from Microsoft includes a copy of the affected DLL, therefore after installing this hotfix you should not experience the problem anymore:
http://support.microsoft.com/kb/971276
Please note:  This hotfix was developed by Microsoft to address a different issue. If you are not sure if this hotfix is suitable for your system, please contact Microsoft Support.
While this fix should resolve the issue you experienced in AutoCAD, it is also highly recommended that you investigate what caused the DLL to become damaged or missing on your machine.
Avto Chachava
Autodesk Product Support
Autodesk, Inc.
Member
tendring
Message 3 of 5 (2,939 Views)
01-14-2011 12:24 AM in reply to: avto
Update for Windows XP x64 Edition (KB971276) this fix dose not work on XP x32 Edition
Product Support
avto
Message 4 of 5 (2,931 Views)
01-14-2011 08:32 AM in reply to: tendring
here is the link to KB971276 for Windows XP 32-bit
http://www.microsoft.com/downloads/en/details.aspx?FamilyId=a005d603-103e-4a73-bcce-0b90dc9e63db&dis...
Avto Chachava
Autodesk, Inc.
Member
tendring
Message 5 of 5 (2,832 Views)
02-01-2011 02:17 AM in reply to: avto
thanks this worked
however i am out of the trial period can you extend this for me? as i have been unable to purchase a copy via the internet ...AutoCAD don't  or will not ship to the UK
As I am an education establishment may you could just give me the log in codes free of charge!
thanks
:smileyhappy:
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
