Have down loaded three times the trial version of AutoCAD Freestyle the last attempt with firewall and AV off however the same message is given before the programme closes via a polite message the we have a problem!
Typically this error occurs when the Windows dll prntvpt.dll is missing or corrupt.
The following hotfix from Microsoft includes a copy of the affected DLL, therefore after installing this hotfix you should not experience the problem anymore:
http://support.microsoft.com/kb/971276
Please note: This hotfix was developed by Microsoft to address a different issue. If you are not sure if this hotfix is suitable for your system, please contact Microsoft Support.
While this fix should resolve the issue you experienced in AutoCAD, it is also highly recommended that you investigate what caused the DLL to become damaged or missing on your machine.
here is the link to KB971276 for Windows XP 32-bit
thanks this worked
however i am out of the trial period can you extend this for me? as i have been unable to purchase a copy via the internet ...AutoCAD don't or will not ship to the UK
As I am an education establishment may you could just give me the log in codes free of charge!
thanks
