Dynamic Blocks Forum
How to control arry pitch in dynamic bloc
2 REPLIES 2
317 Views, 2 Replies
hello,
I'm pretty new user on dynamics blocks.
i would like to be able to control the pitch on properties box of the array in dynamics bloc.
Currently, if i want to change the pitch i must "enter" in the bloc, select the parameter, select the arrau action and modify it...
regards
DAvid
2 REPLIES 2
hwalker
Are you using a POLAR ARRAY?
If you are look at the CUSTOM PROPERTIES at the end of the PROPERTIES. You can change the angle there
Howard Walker
Left Handed and Proud
Emmsleys
To add I've provided a few articles that be of help.
but have you seen this.. post back and let me know if this would help.
Modify the Angle Between the Items in a Polar Array
  1. Select the array.
  2. Click the Angle Between grip.
    The Angle Between grip is displayed on the second item in the first row of the polar array. This grip is displayed only when there are three or more items in the array.
  3. Move the cursor to increase or decrease the angle between the items and then click.
ARRAYPOLAR (Command)
-ARRAY (Command)
Sarah Emmsley
Technical Support Specialist
”Boost
”Tips
”Services
