hello,
I'm pretty new user on dynamics blocks.
i would like to be able to control the pitch on properties box of the array in dynamics bloc.
Currently, if i want to change the pitch i must "enter" in the bloc, select the parameter, select the arrau action and modify it...
regards
DAvid
Are you using a POLAR ARRAY?
If you are look at the CUSTOM PROPERTIES at the end of the PROPERTIES. You can change the angle there
Howard Walker
To add I've provided a few articles that be of help.
but have you seen this.. post back and let me know if this would help.
The Angle Between grip is displayed on the second item in the first row of the polar array. This grip is displayed only when there are three or more items in the array.
