When I click on the empty space on a dashed line, it selects the line. How can I turn this off.
Solved by user181. Go to Solution.
Hello @bbadesignstudio
Put the dashed line on it's very own layer. Then in Properties Manager, lock that layer.
You're confusing LOCK with FREEZE.
When a layer is locked, you can't select objects on that layer. Even the locked layer's objects are visible, they're non-selectable.
@ChicagoLooper wrote:
.... When a layer is locked, you can't select objects on that layer. Even the locked layer's objects are visible, they're non-selectable.
Some people wish that were true [you can Search for topics about it], but it's not. You can't select them in editing commands that would require altering them, like Move/Copy/Rotate/Erase, but you can select them, such as to use as Trim or Extend boundaries, or to LIST.
