When importing pdfs there is a preset scale of 25.4:1 (which corresponds to millimeters to inches). I would like to change this value as needed, based on the actual scale of the pdf drawing, or at least have it at 1:1. Is that possible?
I thought the value could correspond to some metadata of the pdf file which may have been wrongly created, but didn't find anything. Of course I can scale the data to the correct size after import, but it seems unnecessary.
That highlighted scale was defined in the PDF: not much you can do about it in AutoCAD except whatever you can right here after the fact
@pendean wrote:That highlighted scale was defined in the PDF
That's what I thought but, as mentioned, couldn't find where. I'd like to know if there exists at least one pdf file that has a different scale and how would that be achieved. I tried files from different sources and there was always 25.4:1 (I certainly don't work in inches and take care to have the correct units set up). Maybe it's the default for most pdf printers / exporters?
The scale setting you pointed out is something, I can put in 25.4 and then the import is as on paper, in mm. However, if I wanted to scale to the real dimensions, I'd already have to multiply Scale*25.4 and input that, which sucks.
This may bring you some insight
