I have received a 3D file in two formats - with a .PLY and .OBJ extensions. The contents should be the same. How to import it into AutoCAD?
Solved by vladimir_michl. Go to Solution.
PLY and OBJ files can be opened and converted in Autodesk Meshmixer and ReMake. There are also other ways for OBJ:
http://www.cadforum.cz/cadforum_en/formats.asp?fmtin=23&fmtout=1
But the easiest way should be using the OBJ2DWG freeware app for AutoCAD - it adds OBJ import to AutoCAD - see:
https://apps.autodesk.com/ACD/en/Detail/Index?id=3563402343067399513&appLang=en&os=Win32_64
Vladimir Michl, www.cadstudio.cz www.cadforum.cz
