Hello everybody,
I’m using tables for the first time in Autocad 2014. I have made a table with data link from excel, and I have many problems:
Sorry perhaps my questions are not well said because i don't speak english, i speak fench. I have post my questions in the french forum but i have no reply. I hope in the english forum there are users who have worked with tables.
Thanks.
Some of the answers you seek may be in this article:
Bonne Chance
Thank you for the answer.
Capture 1 : options for the data link.
Capture 2 : the table in excel.
Capture 3 : the table in autocad.
Hello
I haven't receive no answer for my questions but since that i have worked on. I think that the practical way to insert and format a table with data link to excel is :
1- Insert a simple empty table. It's not important the style of the table : number of rows, columns, heights .... etc.
2- Right click and Link the first cell with excel by data link. I dot it like this because the titles are not repeated when i insert directly a table with data link excel.
3 - Set the options in the capture joined "data link options" : I have choose these options
Convert Data Formats to Text, Solve Formulas in Excel : yes
Allow Writing to Source File : no.
In this way all changes that i want to make i do it only in excel and not in autocad. Because i have found many problems when making update the table to the source.
Start With Excel Formatting, Do Not Update : yes
In this way no problem if i choose a small text in excel, when i insert in autocad i can scale the table with the appropriate value in order to increase the text. If i don't do this when i update the table from the source after scaling it, it takes the height of the text in excel.
4- Scale the table to the appropriate scale in order to make the text at the appropriate height.
5- Select all the cells and in properties palette change the height of rows and the width of columns. Make sure that you have select the cells not the table. If the table is selected height and width is not displayed in the palette properties.
6- Select the table and the propertie palette and set “repeat top labels” to “yes” in order to repeat the titles when you break the table.
The style, height, color of the text i prefer to make it in Excel, Dimensions of rows and columns i make in autocad. I not work with styles of tables in autocad because it's not practical when we use the datalink from excel.
I solve all the problems i had before when i work this way.
After hours of frustration, I was able to insert an Excel file table when I renamed the workbook to 'SUMMARY'. I had the workbooks with more descriptive names and exclamation marks. Summary is what an extracted data file names the workbook, so I matched that convention.
