Good morning, I'm plotting some designs and came across something interesting... I've attached a few screenshots for reference. For whatever reason the radius and circle lines look shaded after a plot. Everything else is crisp and high quality..
Solved by pendean. Go to Solution.
Is that "plotimage" from inside your PDF viewer? If yes, by chance is that Adobe Acrobat? If yes, try a different PDF viewer, your webbrowser will open PDF files too these days, see if the issue is still there.
If the issue is still there, then your PLOT parameters are at play: an errant plot style table, or lack there of, shademode setting or more. We'll need to see a screenshot of your PLOT command pop-up.
Hi!
So, I opened my plot file using Google Chrome and the plot looks PERFECT compared to opening with Adobe Acrobat...
Do you have a recommendation (or is there) a way to automatically default to opening a PDF through Google Chrome?
Change your Acrobat Page Display settings to match mine
Or only use Adobe's own PDF driver (not sure it's free, and it is Windows based) to plot from AutoCAD exclusively and forever.
