Has anyone used the bconvert or -boconvert function in AutoCAD 2025? When I type either in the command line I get "Select objects to convert to blocks:*Cancel*" in the command line.
Works fine here: by chance, did you opt into the startup "migrate from" tool to import settings from an older AutoCAD version?
Or load an external profile?
Do you have this update installed
@tmcquade wrote:Yes, I did use the migrate tool to import my settings from AutoCAD 2023.
Reset AutoCAD2025 back to defaults, restart your PC, then start AutoCAD2025 back up without the migration tool this time, see if your issue goes away.
