Hi there,
I hope someone can help me with my question:
I wanted to create a reference axis, which should look like the one in the following picture (B):
Does anybody of you know how I can create such an reference axis? Is there a tool for it or is it usually created manually?
Thank you very much in advance & have a nice day.
There are some Section callouts available but none which look exactly like yours. You can make a custom dynamic block by placing the AutoCAD one in a blank drawing, then modifying it in the Block Editor then saving as your custom reference axis.
I made a PDF file of the steps to make a multileader do this (attached). If I understood the question. BTW, this is out-of-the-box.
If you want the little axis line, make a block with the line then instead of picking "Datum triangle filled" select "User Arrow..." and select your block.
I tried to attach a dynamic block, but I keep getting "The file type doesn't match the type of its contents". It is a dwg file. I even tried the bak file. What up?
Hi tbennett,
thank you very much for your help!
With your great instruction, I was able to create it.
Thanks again & have a nice day!
