This may be a silly question, but it's been a minute since I've used the Sheet Set Manager. I have a project where I've built my model in model space. Now I'm ready to add some plan sheets using the SSM - When I insert a new sheet into the SSM, it saves it to a separate file. I seem to recall there used to be an option to insert the new sheet as a layout tab in the existing drawing (not a separate file), but can't figure it out.
You can drag the layout tab and drop it in the Sheet Set Manager or use Import Layout as Sheet.
Thanks Jimmy - I thought there was a way to do it through the SSM itself. I may have been remembering certain behaviour/options from Civil 3D's sheet creation tools. I don't use vanilla ACAD for much these days.
I own a licence to your SSM Properties Editor BTW and love it... it's a great tool!
Another way to add one or more sheets from the SSM is to right click on one of the sheets listed and select "Import sheet..." It will open a dialog box to select files.
Nancy
