When I try to use one of the 3d commands (3DORBIT, 3DROTATE, 3DMOVE) I loose my current view on the screen and Autocad shows me only empty grid. If I click enter it zooms far away out and I have to zoom in again. As the end effect those commands doesnt work.
And also when I click on View Cube nothing happens.
Video: https://www.youtube.com/watch?v=7hxtmddpjZk&list=UU5qHM-osJKYNgAWuwnjZmhw
There was a problem in your drawing with viewport configuration.
I ran AUDIT command:
Command: AUDIT
Fix any errors detected? [Yes/No] <N>: y
Auditing Header
Auditing Tables
Auditing Entities Pass 1
Pass 1 100 objects audited
Invalid viewport-configuration name "*Multiple" found.
Changed to "AUDIT_I_140722164357-20".
AcDbViewportTableRecord: "AUDIT_I_140722164357-20"
Tilemode Viewport Corners Not filling up whole screen Set to 0,0..1,1
Changed to "AUDIT_I_140722164357-21".
AcDbViewportTableRecord: "AUDIT_I_140722164357-21"
Changed to "AUDIT_I_140722164357-22".
AcDbViewportTableRecord: "AUDIT_I_140722164357-22"
Changed to "AUDIT_I_140722164357-23".
AcDbViewportTableRecord: "AUDIT_I_140722164357-23"
Pass 1 2600 objects audited
Auditing Entities Pass 2
Pass 2 2600 objects audited
Auditing Blocks
14 Blocks audited
Auditing AcDsRecords
Regenerating model.
Total errors found 8 fixed 8
Erased 0 objects
changed Visual Style to Concept, than back to 2D Wireframe, and it appears the drawing is good now.
Try it.
Maxim
