AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Zoom out issue using 3DORBIT, 3DROTATE, 3DMOVE - AutoCAD 2014 Mac
6 REPLIES 6
insanoff
833 Views, 6 Replies
When I try to use one of the 3d commands (3DORBIT, 3DROTATE, 3DMOVE) I loose my current view on the screen and Autocad shows me only empty grid. If I click enter it zooms far away out and I have to zoom in again. As the end effect those commands doesnt work.
And also when I click on View Cube nothing happens.
Video: https://www.youtube.com/watch?v=7hxtmddpjZk&list=UU5qHM-osJKYNgAWuwnjZmhw
6 REPLIES 6
maxim_k
in reply to: insanoff
Never seen such issue. Maybe something wrong in your drawing?
Could you attach the drawing here?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
insanoff
in reply to: maxim_k
It's because of drawing, but I how it can be?
Please find attached file.
maxim_k
There was a problem in your drawing with viewport configuration.
I ran AUDIT command:
Command: AUDIT
Fix any errors detected? [Yes/No] <N>: y
Auditing Header
Auditing Tables
Auditing Entities Pass 1
Pass 1 100 objects audited
Invalid viewport-configuration name "*Multiple" found.
Changed to "AUDIT_I_140722164357-20".
AcDbViewportTableRecord: "AUDIT_I_140722164357-20"
Tilemode Viewport Corners Not filling up whole screen Set to 0,0..1,1
Changed to "AUDIT_I_140722164357-21".
AcDbViewportTableRecord: "AUDIT_I_140722164357-21"
Changed to "AUDIT_I_140722164357-22".
AcDbViewportTableRecord: "AUDIT_I_140722164357-22"
Changed to "AUDIT_I_140722164357-23".
AcDbViewportTableRecord: "AUDIT_I_140722164357-23"
Pass 1 2600 objects audited
Auditing Entities Pass 2
Pass 2 2600 objects audited
Auditing Blocks
14 Blocks audited
Auditing AcDsRecords
Regenerating model.
Total errors found 8 fixed 8
Erased 0 objects
changed Visual Style to Concept, than back to 2D Wireframe, and it appears the drawing is good now.
Try it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
insanoff
Thank you for quick reply!
AUDIT doesn't work for me. And I also tried from Concept to 2DWireframe.
maxim_k
You can try to search solutions for "Tilemode Viewport Corners Not filling up whole screen Set to 0,0..1,1" - I tried, but have not found clear answer.
Anyway, I'm sure that this is viewport configuration corruption issue. Why it occurs? Don't know, as I don't know your workflow with this file.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
insanoff
Just copied and paste content from source file to new file. And it works!
Thank you Maxim!
”Boost
