When I use XREF in model space, the XREF file shows up very light. It looks faded, and is too difficult to see or work on it. Is there a way to make the XREF file appear normal in color and intensity?
Solved by maxim_k. Go to Solution.
Welcome to the Autodesk Forums!
You can control Xref shading in AutoCAD Preferences:
Select menu AutoCAD -> Preferences, tan select "Look & Feel" tab.
Maxim
