Hello, I am running auto cad for mac lt 2015 on os x yosemite. I have come across a very serious issue.
When i insert any drawing created in earlier version as xref in autocad for mac lt 2015, and overlapp it on the existing drawing, suddenly, the object selection hightlight, which, previously was showing as dashed lines, when selected, stopped showing as dashed line. Even after deleting the xref, object highlight does not show as dashed line, when selected, instead what i see was just three grip points. In such case, it is very difficult for me to judge, whether the object is selected or not.
This issue does not arise when, i insert a drawing as xref in the current drawing generated in autocad lt 2015.
I have tried to google the issue, and looked in to system variables, but it seems everything is configured correctly. Tried to uninstall-reinstall autocad for mac lt 2015 couple of times, but in vain.
Pl. help me.
Solved by maxim_k. Go to Solution.
Thanks for your reply.
Even i tried auto cad for mac lt 2015 on os x mavericks. There was no issue. But with os x yosemite, this is the problem i am facing.
Tried out solutions so far:
01. uninstalling-reinstalling auto cad three times, but no issue.
02. Tried out on different user account. But got the same issue.
03. Tried out on my admin account. But no solution.
When inserting file as xref, created in auto cad lt 2015 for mac, i face no issue. It just happens with files inserted as xref, created in older versions.
Rikhav
Hi, Thanks for helping me out.
After your reply, suggesting, that autocad for mac lt 2015 was working without problem described by me, on os x yosemite, and, after trying out everything, googling about the problem, was not able to find out the answer.
Then, I decided to clean install os x yosemite as well as autocad for mac lt 2015. Till then, everything is fine so far...
Thanks once again, for your prompt reply...
Will let you know, if the problem, again happens...
Rikhav
