Welcome to the Autodesk Forums!
Unfortunately at the moment there is no direct solution to this problem, but I'm aware that AutoCAD for Mac developers are working on this.
Actually the problem was already discussed here on the Forums, for example:
http://forums.autodesk.com/t5/autocad-for-mac-general/xrefs-in-a-mixed-environment/td-p/3598902
Plus I know that Chris Wade has some workarounds for the problem. I think you can try to contact him (write a private message), maybe he can resolve your problem in some way.
Maxim
I imagine that many users are using xRefs, and that mixed environments users see this problem a lot.
If we cannot load the xReferenced files, then we won't be able to use AutoCAD on the Macs.
I hope that the AutoCAD developers can come up with some solution to is.
I will also try to contact Chris Wade, and see if he can helps us with some tips.
Thank you for your reply.
Andras
