It looks like there is some confusion when it comes to just what doesn't come in ACAD for Mac 2011 (AKA ACAD 2002). Here is a link to the TS doc right from Autodesk: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15833488&linkID=15839490
Here is the text from that page:
2011: What AutoCAD features are not available in AutoCAD for Mac
Published date: 2010-Oct-14 Applies to: |
Issue
You are familiar with AutoCAD 2011 (for Windows) and you want to know what features are not available in the first release of AutoCAD 2011 for Mac.
Solution
Although AutoCAD 2011 for Mac is based on AutoCAD 2011, it was written to be a native Mac application. As such, it is a new and separate product and not simply a port from the Windows version. In the first release of this new product, there are some features and functionality that exist in AutoCAD 2011 that are not yet available in AutoCAD 2011 for Mac, including (but not limited to):
Other Functionality
if i could pay for a real version, I would be willing. Free doesn't make a poor attempt acceptable.
HELP! I can't get a command line. I've force quit auto-cad and when i re-opened it, still no command line. I guess the 'official' command line could be hidden, but no commands are functional. I am using the trial version of this, otherwise I would be very upset. But this is disappointing. If done right, autoCad on a Mac would be great. Even still, the 2011
I will now switch back to my PC. While it would be great and convenient to have this software on my Mac, i found that Autocad functioned better on a Mac on Bootcamp than a PC. So, I will continue with that. This is really surprising. AutoCad has brilliant software.
AutoCad has brilliant software......................smileyvery-happy:
Edited by
Discussion_Admin
The following will reset your application configurations and restore the command prompt.
The disadvantage to this cure is that any other configuration changes you have done will also reset.
Keeping a list of changes would be a good idea.
On the menu select AUTOCAD ==> Preferences ==> Application.
Select the "Reset Application Options"
for ****'s sake. it sure is nifty that i can draw some lines with mac, but I would LOVE to: create Table Styles, Layout properly, and eTransmit.
Dear AutoDesk-
Can you please submit a WORKING version of AutoCAD for Mac?
I have been running 2011 PC on parallels, and it runs smoothly; for the most part. I have experienced one main "glitch."
I have created a custom sub-menu through the CUI interface. This menu allows me to enter specific drawing commands and change layers with one click.
I have attached my custom sub-menu to the o-snaps menu that comes up when "mbubbonpan" is turned on so that I can have access to the OSNAPS overrides menu. What is happening in 2011 is that the new line defaults to the last point of the last object drawn, instead of to the osnap override. This did not happen when I ran the custom menu in 2007, so I believe it is something that has to do with my change to 2011. I am using the same file that I created for 2007, which may also be adding to the problem.
Other than that, it is working well in parallels.
Does your situation happen when you enter the @ sign for selecting the second point, causing the line to end somewhere else? If so, that's the issue I have. But I only have it on my PC running Autocad 2011 on XP. On my Mac running Autocad 2011/Windows XP on Parallels, the issue doesn't happen.
No, if I put in a destination using the @ symbol, everything is cool. It is happening when I initiate the command and want to specify a start point.
Anyone who knows anything about a release of Autocad for Mac 2016?
From january 2016 on, I start as an independent draftsman an I have to decide wether to buy a Mac version, or stick to Bootcamp and buy a Windowsversion.
I rather prefer to stay on my iMac however.
The bggest shortcomings for my kind of drafting is the poor possibilities to create Dynamic Blocks. I want to have it all te same as in the Windows-version. I sure miss the Lookup-tables, and a decent workout for visibility states.
The second most issue is the lack of Tool Palletes.
And as a third point: Data extraction...
I hope they solve this soon, since the investment in a Full version is a big dump of euro's for me if it lacks these items
