When I try to extract the attribute information from a group of blocks, in order to export to a spreadsheet, I select the blocks, type ATTOUT, and get the message "unknown command" How can export/import attribute data in ACAD Mac?
Solved by maxim_k. Go to Solution.
This command is from Express Tools, which are not available in AutoCAD for Mac.
Currently you can use only command line version -ATTEXT (with hyppen) to extract attributes.
HTH
Maxim
I have been evaluating autocad for MAC 2014 only today!, it is the third instance I find the same answer. Let me clarify, I was looking for different subject matters though. Maybe you can recommend "go to google maps instead of mac maps"; just as Tim Hook did some months ago. It would be hilarious you end up buying Parallels and selling bundled packages by the name of: "Autocad for MAC".
Oh well, I can go on and on, I have not reached the LISP programming language yet, friends have told me good luck, but I don't need it, you do.
Greetings from México
Welcome to the Autodesk Forums!
Here you can find short tutorial about attribute data extraction in AutoCAD for Mac:
I also attached files to complete this tutorial.
HTH
Maxim
