In this case the only one way to manage Layer states is to use stAte option of -LAYER command (I mean command line version of LAYER command):
State option:
Saves and restores the state and property settings of the layers in a drawing.
?—List Named Layer States Lists the named layer state (LAS) files in the support path for the drawing.
Save Saves the state and properties settings of the layers in a drawing under a specified layer state name. When saving a layer state, you specify which layer settings are affected when the layer state is later restored.
Restore Restores the state and property settings of all layers to previously saved settings. Restores only those layer state and property settings that were selected when the layer state was saved.
Edit Changes the saved layer settings for a specified layer state. When the layer state is restored, the specified settings are used.
Name Changes the name of a saved layer state.
Delete Removes a saved layer state.
Import Loads a previously exported layer state (LAS) file, or layers states from a file (DWG, DWT) into the current drawing. Additional layers may be created as a result of importing a layer state file.
Export Saves a selected named layer state to a (LAS) file.
Maxim
