Any idea how to do the same thing in ACAD for Mac 2011. Same error message.
"unable to find main dictionary. could not start speller."
Edited by
Discussion_Admin
There could be several problems:
1. Check which dictionary established as main in AutoCAD: type DCTMAIN at the command prompt and look what you get. It should be "enu" by default.
2. Check AutoCAD->Preferences->Application tab-> Support File Search Path: "/Applications/Autodesk/AutoCAD 2011/AutoCAD.app/Contents/Resources/Support" folder should be in it
3. This step depends on #1, if for example you have DCTMAIN="enu", then go to "/Applications/Autodesk/AutoCAD 2011/AutoCAD.app/Contents/Resources/Support" folder (go to Application folder, find AutoCAD.app in it, right-click on it and select "Show package contents", then navigate to "Contents/Resources/Support" folder) and find enu.dct file in it, it should be there.
Maxim
Can not find this
I am useing Autocad civil 3d 2014.
Attached jpg shows the error that I am getting.
Can not find Application tab in it?
hi,
I also have this problem but i am in the right forum i.e auto cad i just need to know where to find this enu.dct file cause the parth you have showed i.e Check AutoCAD->Preferences->Application tab-> Support File Search Path: "/Applications/Autodesk/AutoCAD 2011/AutoCAD.app/Contents/Resources/Support
hasn,t got the file you mentioned and everything in the support folder seems to be greyed out. Please can you help sort this out as i am getting the
Unable to find main dictionary 😞
I am using auto cad 2015 though!
PLease help
hi maxim,
Please help me im still not winning. I still get the messgae "unkown dictionary "point" could not start speller. I get this message when i douvle click text to edit it. I have to press entre all the time to pass the error and edit. I know you told me to to relocate a file. But im not ablt to find this file and past it. If you can help me or maybe direct me to who i can call directly. Thank you for your help and trying
The pest 😉
kryalan Sundurm
