AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Unable to find main dictionary
15 REPLIES 15
Message 1 of 16
7540 Views, 15 Replies
Any idea how to do the same thing in ACAD for Mac 2011.  Same error message.
"unable to find main dictionary. could not start speller."
Edited by
Discussion_Admin
15 REPLIES 15
Message 2 of 16
maxim_k
There could be several problems:
1. Check which dictionary established as main in AutoCAD: type DCTMAIN at the command prompt and look what you get. It should be "enu" by default.
2. Check AutoCAD->Preferences->Application tab-> Support File Search Path: "/Applications/Autodesk/AutoCAD 2011/AutoCAD.app/Contents/Resources/Support" folder should be in it
3. This step depends on #1, if for example you have DCTMAIN="enu", then go to "/Applications/Autodesk/AutoCAD 2011/AutoCAD.app/Contents/Resources/Support" folder (go to Application folder, find AutoCAD.app in it, right-click on it and select "Show package contents", then navigate to "Contents/Resources/Support" folder)  and find enu.dct file in it, it should be there.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 16
lee_cheniere
in reply to: maxim_k
Can not find this
Message 4 of 16
maxim_k
Could you clarify:
What exactly you can not find?
Can not open AutoCAD Preferences dialog or can not find Application tab in it?
And what is the main problem?
Do you get an alert about main dictionary?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 16
lee_cheniere
I am useing Autocad civil 3d 2014.
Attached jpg shows the error that I am getting.
Can not find Application tab in it?
Message 6 of 16
maxim_k
Sorry, but you are at wrong Forum.
You are using PC version if AutoCAD, but here is AutoCAD for Mac Forum.
In Windows version of AutoCAD you have to look in Files tab (the first one) in AC Preferences.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 16
maxim_k
It is better to ask here:
forums.autodesk.com/t5/AutoCAD-Civil-3D-General/bd-p/66
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 16
lee_cheniere
Yeha, I guess that would work better if I was in the correct form, lol, good to know its a problem in both versions.
Message 9 of 16
kryalan
in reply to: lee_cheniere
hi,
I also have this problem but i am in the right forum i.e auto cad i just need to know where to find this enu.dct file cause the parth you have showed i.e Check AutoCAD->Preferences->Application tab-> Support File Search Path: "/Applications/Autodesk/AutoCAD 2011/AutoCAD.app/Contents/Resources/Support
hasn,t got the file you mentioned and everything in the support folder seems to be greyed out. Please can you help sort this out as i am getting the
Unable to find main dictionary 😞
I am using auto cad 2015 though!
PLease help
Message 10 of 16
maxim_k
Are you using AutoCAD for Mac?
When do you get this alert from AutoCAD? Please provide more details.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 16
kryalan
Yes I'm using auto cad for Mac 2015. I get the message when I double click text to edit it.
Kryalan Sundrum
0925658177
Message 12 of 16
maxim_k
If you checked DCTMAIN system variable and it is "enu" and if you cannot find end.dct file inside AutoCAD application folder (see the 2nd post in this topic - just substitute 2011 for 2015 as you have 2015 version), than you need to try to reinstall AutoCAD.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 16
maxim_k
....or find end.dct file somewhere and place it to specified folder.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 14 of 16
maxim_k
in reply to: kryalan
Another solution that you can try if you don't need spell checking:
Set DCTMAIN system variable to "none" - type at the Command prompt DCTMAIN, hit Return and than type point and hit Return again:
Command: DCTMAIN
Enter new value for DCTMAIN, or . for none <"enu">: .
Command:
This will set main spelling dictionary to "none".
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 16
kryalan
hi maxim,
Please help me im still not winning. I still get the messgae "unkown dictionary "point" could not start speller. I get this message when i douvle click text to edit it. I have to press entre all the time to pass the error and edit. I know you told me to to relocate a file. But im not ablt to find this file and past it. If you can help me or maybe direct me to who i can call directly. Thank you for your help and trying
The pest 😉
kryalan Sundurm
Message 16 of 16
maxim_k
hi kryalan,
what about DCTMAIN system variable?
Which value it has on your AutoCAD installation and what System language you have in OS X?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
