Is possible to use the command txt2mtxt in Autocad 2013 for Mac? If not, is there a similar command to join several texts into a single mtext?
Solved by maxim_k. Go to Solution.
Yes, possible.
In attachment you will find slightly modified version of TXT2MTXT Lisp routine (free routine from www.dotsoft.com). With this routine you can convert to single line TEXT to MTEXT even if it has one string, just follow prompts in Command line.
Maxim
Attempted to use this, it is Windows based, not Mac. Hence, not what I am looking for.
But, thank you again.
Richard
so then where does the *.lsp files go on a Mac. I was unable to locate, which is why I determined that it was windows based. Or am I mistaken?
Richard
I have AutoCad 2015 for Mac, but there is not command MLSTYLE, as well in Format there is no Multiline Style. Is there any solution? If it is possible please explane with simply words because I am not pro in IT. Thanks 🙂
