Is there a way to turn off windows laso so when I try to select objects I go back to a rectangular selection and not a laso? Apparently, for the Windows version, you can turn off windows laso, but I can't find where it could be truned off on Autocad 2015 for Mac. Frankly, I prefer a rectangular selection.
Baharm
Solved by maxim_k. Go to Solution.
Thank you so much for your prompt reply. This option isn't documented on the link that you provided. Autodesk should add 3 to the list.
Thanks again
