I'll just switched from AC Win to AC mac, and I've few problems, and the most important is the impossibility to turn off layrs on one paper space. When I turn off layers on a presentation (paper space) it's turn it off on every paper spaces and model space. Does anybody have a solution for this problem? It's very problematic for the creation of different plans, like electrical, ceilling, plombing.... on the same model. The only way I found, is to draw thoses plans, on a .xref basic plan, but it's not an easy solution for me. Thanks. Eric
Solved by maxim_k. Go to Solution.
Hi Eric,
In order to hide contents of a specific layer in viewport you have to VPFreeze it:
Activate viewport, in Layers palette VPFreeze necessary layer using VPFreeze column:
Or use LAYFRZ command inside viewport, but don't forget to check Settings option of this command (should be Settings->Viewports->Vpfreeze)
Maxim
