I have a jpeg image of a floor plan with the dimensions on it and I need to have it drawn to scale in autocad so I can add a design. I am clueless as to how to do it, is there a way I can put the jpeg in to scale and trace around it?
Solved by maxim_k. Go to Solution.
Welcome to the Autodesk Forums!
Of course, it is possible.
You need to use IMAGEATTACH command,
then SCALE with Reference option,
than trace attached image:
Maxim
