I intalled AutoCAD LT 2013 for Mac and the Menu Bar (not a ribbon) and the Tool Bars are missing. When it initiated all of the UI tools were missing, ei command line, status bar, layer, properties, references, etc. I manually added those components through commands. But, the Menu bar and Tool Bars are NO Where to be found. Even when I type in "TOOL" nothing happens. In addition, after using this for a week, I have crashed it 12 times usually in the middle of a command. Hot grip use crashes it for example.
Has anyone else encountered these problems? Found a solution?
Thank you!
Angela
Solved by wei503. Go to Solution.
Thank you. I followed the Youtube like and that's got rid of the alert. My previous plot style settings don't seem to be available anymore. I used to have the option to select 'Monochrome RR' (my amended version) when I clicked print/edit page set up. It's no longer there. (See screen grab). Sorry, I know these are very probably basic questions!
You need to expand window with this button:
Then you will see "Plot Style" selection dropdown list:
Maxim
Of course! Thank you! I'm on a deadline and don't think I'm thinking straight! Do you know how I amend the A3 setting so that it doesn't cut the border off? (Someone else set this up for me previously and it seems to have got lost too). Thanks so much for your help.
Create Custom Paper size with zero margins and assign it to page setup:
Maxim
