I intalled AutoCAD LT 2013 for Mac and the Menu Bar (not a ribbon) and the Tool Bars are missing. When it initiated all of the UI tools were missing, ei command line, status bar, layer, properties, references, etc. I manually added those components through commands. But, the Menu bar and Tool Bars are NO Where to be found. Even when I type in "TOOL" nothing happens. In addition, after using this for a week, I have crashed it 12 times usually in the middle of a command. Hot grip use crashes it for example.
Has anyone else encountered these problems? Found a solution?
Thank you!
Angela
Solved by wei503. Go to Solution.
Hi Angela,
Regarding to the menu/tool palette missing, could you please try the steps below:
click AutoCAD LT 2013 menu > Preferences > go to tab Applications > click Reset Application Options button
About the crashes, did you send out the crash report? If so, please let me know what email you input when sent the report.
And please let me know the version of your AutoCAD. You can get it by click menu AutoCAD LT 2013 > About AutoCAD LT 2013
Wei
I performed the reset. No change. The error reports were sent under DJAngelaV@yahoo.com . Thank you.
I am also having the same problem. I have tried resetting the application options. It seems to make no difference. I have no menu and no tools in the tool palette.
I have also a simular problem.
My autocad was crashing and now there are no tools on the left an my title bar is gone
Hi
Maybe I did something wrong yesterdag when i tried it, but now it works with the preferences!
I reinstalled autocad and it's back.
Thanks a lot
Lieselore VDC
If reset does not work, maybe there are some permission problems.
Please try this solution:
Wei
I did this and it works...but now my macros/micros that I created myself are gone and I need them back immediatey. Please help!
Hi there,
This has just happened to me on the 2015 version. The attached screen grab is the only menu I have. Do I need to 'reset Autocad', 'Reset palettes' or remove from my computer and reinstall? I'm worried about losing my settings.
Ruth
