I have downloaded Autocad 2011 mac (Student version) yesterday and it installed it on my Macbook pro 15" (Core i5, 4Gb RAM and NVIDIA GeForce GT 330M) but der is this problem, it does not any menu and even no tools I have also attached Screenshot of my autocad...... please help me.....
Hi All,
Please apply AutoCAD 2011 for Mac Update1:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16105699&linkID=15839491
This should fix the issue you are seeing with missing tools/icons.
Please reply either way whether it works or not.
thanks,
Pavan Jella
AutoCAD Test Developement
Autodesk Inc
hi thanks for your help but no it didnot work for me .im still using my pc for autocad . to bad.
I Tried all the solutions above but I still don't get my Toolset pallet.
Another solution?
Thx
Still doesn't work on my mac!
Thx for searching a solution
Jens,
Belgium
Can you double check the workflow posted by me? I have done a remoted desktop session and it definitely worked for me. Can you send us a screen capture of your problem?
djenzz
you're missing a space
add a space after ./copyreg.sh and before /Programmas
It didn't worked also. But now I Reinstalled Autocad and when I typed TOOLSETS it directly showed so my problem is solved.
Thx to all!
Greetings
Jens Vanhecke
Belgium
I had the same problem! After reinstall on my Mac, acad is running with toolset.
Maybe a dutch version problem?
I had this problem too.
I actually tried the recommended fix from this discussion a couple of times (for accuracy). Which didn't work.
Redownloaded and installed which took some time, but worked.
NOTE: If you are reinstalling, remember to click the DELETE AutoCAD preferences button. It is necessary to perform the reinstall and fix the problem.
Steve
