I am having problem with opening the Text STyle box. It shows for a second on my screen and then dissappears and my computer freezes after that. I need to create new Text Style , how can I open the Text style box?
Try:
1. to "Reset Application Options" from Application tab of AutoCAD Preferences
or
2. Just exit AutoCAD and try to delete AutoCAD preferences file from ~/Library/Application Support/Preferences folder, it's should look like "com.autodesk.AutoCAD.R18....plist" (the remaining ... depends on AutoCAD version)
Maxim
Thank you! I was having the same problem, with a few other windows as well, page setup for example. I run am running on an iMac no external monitor. I thought it may have something to do with limited processing power (2.8GHz when ACAD wants minimum of 3).
Hi
Sorry, I did not understand. Have you managed to solve the problem with "disappearing" dialog boxes?
If you have, that's OK.
And about processor speed - it doesn't affect dialog box behavior at all, it seems that you confused processor speed and amount of RAM (in Gb).
Maxim
Maxim
