I seem to have a problem with my mouse moving accross the screen when in PSPACE. It is like it is jumping to a snap grid, although this is always switched off.
This only happens when there is no command active.
It also does not occur outwith the sheet (ie to the grey area at the side)
Any ideas for a solution?
Solved by JohnRennie. Go to Solution.
and its only when i am zoomed in on the paperspace, makes it impossible to navigate the drawing HELP!!
Nope, no solution.
IIt seems to be worse when you have multiple views.
Only workaround is to lock your viewports and work within them, keeping all notes, etc. off PSPACE.
But yes, very annoying
Almost impossible to use now. Anyone know if its a graphics card issue? only sticks when in the page and only on certain drawings. Autodesk?????? Misha?????
I have a ATI Radeon HD 5750, so nothing out of the ordinary really. I have yet to have a drawing where it is not an issue.
I think i have resolved it (kind of) i found it was due to an xref (title block in this instance) that was inserted into the pspace. either deleting the xref or putting it on a separate layer and turning it off seems to do the trick. not sure why its has started doing thins tho, better workaround tho
You're right. It was the xreffed titleblock in my case too.
Still not ideal as the only time I'm in PSPACE is to set out a drawing, for which I need to see my titleblock.
Thanks for the help.
Hi John,
As I have not had such issue with "Sticky Mouse movement in PSPACE" (maybe my title blocks are very "light"), could you post some of your title block? Or send it to my e-mail: maximkanaev at yandex dot ru. I want to test it on my system.
Maxim
sure, see attached. i have a feeling it may have something to do with the Mtext block and font used. when i exploded the whole thing and re-named it, it inserted fine into a new drawing and there was no issues with the cursor movement.
Try this one and see how you go. I have a fair bit of text attached and also a jpeg logo which may, or may not, be affecting the performance
Cheers,
John
update - i exploded the 'copyright' text block in the title block and seems to have rectified. i wonder if that particular font (century gothic) is un-stable in CAD? who knows
Following some issues where I had to reset the SUBOBJSELECTIONMODE to 0, and SELECTIONCYCLING to 0 my problem appears to have vanished.
