I am new at using autocad and i am having some trouble setting up my page to scale. I have imported 6 templetes with a title block that come with the programme Autocad all in the one file. These need to all be A3 size and emable me to save a a PDF and email. I am then also having trouble when adding lines into the plan it isnt adding up to be the same size and wont fit into the title block drawing. I have checked that the units are set to 1:50 but the lines i am trying to draw are too big? when i have been told to specifically use A3 size. HELP what am i doing wrong? I am using a Mac computer.
Any help would be greatly appreciate.
Sarah
Welcome to the Autodesk Forums!
Please describe your workflow in more details:
- are you using title block(s) in Layout(s)?
- where you put your main geometry? in Model space or in layout?
- have you created viewports in Layout?
- how big is your model in real world units? In order to fit to A3 paper at 1:50 scale it should be no more than 18x13 metres.
Maxim
Thank you for your reply.
Yes i am using title blocks from the layouts.
What i am wanting to do it create a project with the following
1x Floor plan
4x Elevations
1x Section
all to 1:50 Scale in the one file all with title blocks. I also need to be able to save as a PDF and compress file.
Think i should start again........
Sarah
Sorry didnt see your reply..
The dimentions of the shops are
9300mm x 4850mm- Floor Plan to a 1:50 Scale A3 page size
For the elevations the height is 2700mm
Sarah
Hi Sarah,
In theoretically it should fit.
See attached DWG.
Maxim
Yes thats what i thought so what am i doing wrong when setting up my page with title block because when i draw the dimention line to one of the measurement it goes off the page. Is it the title block i added did i set it up wrong?
Sarah
Okay will check i used the sheet sets provided there was a choice between a few architectural imperial or architectural metric. I did this by going
- insert
- layout
-Layout from templete.
How do it know which one is 1:1?
I was wondering i could use the document you attached previously as that is exactly what i have been trying to do? All floor plan, elevation 1, 2, 3 and 1 section all on 1x A3 page 1:50 scale i need to add more detail and fit out the inside of the shop but this set up would be a great start and much appreciated. i have attached the existing floor plan and elevation so you can see what i am trying to do.
