I am unable to save .dwg files as a template. Following the procedure from the HELP system, all OK until click save, at which point nothing happens and am returned to the current drawing.
I have previously (with LT2014) saved a dwg file as a dwt file, so why not now with LT2015?
My current opening system is OS X Version 10.10.1.
HELP!!!!
Welcome to Autodesk Forums!
On Mavericks I don't have any troubles with saving file as template (DWT format).
I use menu File->Save As, than select .DWT in file format, this automatically brings me to the default drawing template folder, than I give the name to the template, than click OK in "Save As" dialog, than AutoCAD asks two additional questions:
Command: _saveas
Enter Template Measurement [English/Metric] <Metric>: M
Enter a template description:
Command:
I hit Return two times and the window title shows now the name of the template I just saved.
Maxim
HELP!!!!
Hi alanfw,
Thanks for connect with Autodesk!
First, AutoCAD for Windows and Mac doesn't have same process during save dwt. Mac using two command prompts Maxim mentioned instead of 'Save Template Options' Dialog. So you need press <ENTER> two more times to finish the save.
With above steps, I can't reproduce this issue on my 10.10.2. Can you clarify your file location when you select DWT as the drawing saved format?
Or is there any error message logged in Console?
WHY WHY WHY hide it in the command line. I figured this out a few months ago and promptly forgot. I just spend the last 45 minutes trying to figure this out. Thanks for posting this solution. Thank you. G
