One of the many things I miss - the Windows Autocad RENAME facility, which makes rationalizing layer and blocknames so easy.
Unless I am missing a trick, layers etc can only be renamed individually on Mac ACAD. Has anyone got a clever LISP routine to emulate the way they can be batch renamed in Windows? Or another solution?
thanks
Still no solution to this. Even the command line -rename does not allow the use of a wildcard to (for example) prefix all layers. So:
-rename
la
AA-*
Fails at the 3 line.
BTW, this command sequence doesn't work also in AC 2012 for Windows, the same situation with dialog box version of RENAME command in AC for Windows.
Maxim
