Where is the remove AutoCAD application for a complete deletion of AutoCAD 2013 on a Macintosh? There is no such app in the AutoCAD 2013 folder nor is it inside the app package.
Solved by maxim_k. Go to Solution.
Welcome to the Autodesk Forums!
The "Remove AutoCAD.app" is inside "/Applications/Autodesk/AutoCAD 2013" folder:
Please, check it once again.
Maxim
I have this same problem. I have quit all open sessions of AutoCAD, yet the uninstaller program never completes the uninstall and hangs on this point of the process:
There is no way to click "Continue". The uninstaller package remains responsive as I can click "Back" and quit it, but cannot get it to complete the uinstall process. Know of any solutions?
Thank you!
Huh, oddly installing AutoCAD for Mac 2015 allowed me to successfully remove the 2013 version.
Hi
I have the same issue, the uninstaller does not want to quit. Have you been able to resolved it.
YD
i have the same issue. would be good if someone can help.
i have a trial full autocad 2013 on my mac, and a licensed version of 2015LT, i want to remove the 2013 version and the unistaller freezes as per lianeoyang screenshot
regards
Welcome to Autodesk Forums!
If you have OS X 10.10 (Yosemite) on your Mac - have you true to install AutoCAD 2013 for Mac Service Pack 3 from here:
http://knowledge.autodesk.com/support/autocad-for-mac/downloads/caas/downloads/content/autocad-2013-...
According to README for this Service Pack, which you can find here:
http://knowledge.autodesk.com/sites/default/files/file_downloads/AutoCAD_2013_and_AutoCAD_LT_2013_Fo...
SP3 installation resolves:
"General Service Pack Updates
The following general changes and improvements have been made:
Plot
- Image corrupts in plot result.
Yosemite
- Two fingers moving on trackpad trickers zoom instead of pan.
- Uninstall hangs."
Maxim
@oari09 wrote:
this thing is completely broken I already installed the SP3 and still the problem persist. I feel like what I installed on my mac is cracked program, I used to have windows and **** like this always happen...
Since up to now I cant find an option to edit my last message, I can Confirm The solution:
Note: if you have problems with earlier or other versions theres a chance that this could work, give it a try.
Cheers.
Omar.
Hi, I am experiencing the same issue for a long time. I am running on El Capitan and my AutoCAD 2013 does not remove, tried to download Service packs, but it is not possible in this version of OS. Then downloaded AutoCAD 2016 for Mac but it still did not allow me to uninstall 2013 version.
Could you help me please, what might be my otions uninstalling it?
BR,
Eva
