AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Red circle appears when using tools such as "Linear Dimension"
1 REPLY 1
2655 Views, 1 Reply
I just recently upgraded from the 2007 version of Autocad to the 2013 Mac version. When i try to use tools such as the Linear Dimension tool a red node (A circle with a cross inside) appears and locks on too specific intersections which prevents me from doing what I need. Any help would be appriciated. My pointer is nowhere close to where the "Red Node" is locking.
I also am wondering about the text. After I get the dimension right D=........ comes up. If there is a way to get rid of this it would be greatly appriciated.
I have attached a file showing exactly what is happening.
Thanks in advane for all of the help.
Tags (2)
1 REPLY 1
maxim_k
Welcome to Autodesk Forums!
You are using wrong dimension tool: constrained dimension from parametric feature instead of ordinary dimension.
Try to use menu Dimension-> Linear, or use dimension tool from Annotate tab of Toolsets palette, or in command prompt type DIMLINEAR, DIMALIGNED, etc.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
