AutoCAD for Mac General Discussion
jesusmerly
Message 1 of 6 (376 Views)
Reconciling Layers
376 Views, 5 Replies
05-12-2011 01:17 PM
Whenever I get a notice to view unreconciled layers, I select yes.  However, a dialogue screen comes up asking for a template to select from.  If I select a template, a new drawing opens up.  How do I just view the list and reconcile the layers?
MILESarch
Message 2 of 6 (277 Views)
Re: Reconciling Layers
12-05-2012 12:24 PM in reply to: jesusmerly
Was there ever an answer to this?  I have 2013 and am experiencing the same.  Strang.
maxim_k
Message 3 of 6 (265 Views)
12-06-2012 11:35 AM in reply to: MILESarch
This is definitely a defect (or bug, if you want).
An I can explain what's happens.
When you select "YES" in this dialog:
AutoCAD should create layer filter (group in AC for Mac), that contains all Unreconciled layers and show contents of this group in Layers palette. This happens in Windows version.
It appears that the internal "script", triggered by pressing the button YES, was included in Mac version exactly as it was in Windows version. If you look at the command prompt after you select YES, you will see:
Command:
Current layer:  "0"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]:
Current layer filter: "Unreconciled New Layers"
Enter a layer filter option [New/Set/Rename/Edit/Delete/eXit]:
Enter layer filter to make current:
Command:  Unknown command "+LAYER".  Press F1 for help.
Command:  Unknown command "UNRECONCILED".  Press F1 for help.
Command:
Command:
Command:
LAYER
Let's look closely at this:
1. AutoCAD calls -LAYER command, then with undocumented option FI (filter) sets filter (group) "Unreconciled New Layers" current. Everything seems OK, but then
2. The internal "script" calls undocumented +LAYER command, which exists in Windows version, and doesn't exists in Mac version. With this command current "Unreconciled New Layers" filter (group) shows in Layers palette. The options of +LAYER command includes the names of all filters, defined in drawing file, and allows to switch filters without going to Layers palette, thus the command sequence should be:
+LAYER
But as on Mac version there is no such command as +LAYER, AutoCAD for Mac stops at +LAYER:
Then it continue to read next word from "Unreconciled New Layers" sentence - it is "Unreconciled" and gives reply:
Next word is "New", and AutoCAD knows such command and calls NEW command which open dialog for Template selection. This is the result you see on screen.
And the last word is LAYER - you see it at the end.
Maxim
Architect
MARSS
MacACAD | MARSS
MILESarch
Message 4 of 6 (262 Views)
12-06-2012 11:48 AM in reply to: jesusmerly
Very detailed reponse and expaination Maxim, thank you.
I am assuming, based upon the date of the original post, that this has been reported to Autodesk and they are aware of it.  Therefore there is no need to file a bug report.  Am I correct in this assumption?
maxim_k
Message 5 of 6 (257 Views)
12-06-2012 12:04 PM in reply to: MILESarch
Not sure, maybe developers are aware...
Maxim
Architect
MARSS
MacACAD | MARSS
Employee
micahdickerson
Message 6 of 6 (227 Views)
12-18-2012 04:54 PM in reply to: maxim_k
Hi jesusmerly, pbfarch, and Maxim,
Thanks for your posts!
Yes, we're aware of this issue and are working on a solution.  Please stay tuned for more information.
Micah Dickerson
Product Manager, AutoCAD for Mac
