AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Publish command
6 REPLIES 6
821 Views, 6 Replies
Publish command
Am I missing something really simple here?
When I use the publish command it will only add modelspace and a single layout. My drawing has up to ten layouts but I can't seem to get these to show in the publish dialogue.
6 REPLIES 6
bgerold
I came across the same problem. My layout has 9 Layouts but only 2 Layouts appear if i "add open drawings" in the publish dialog box.
This isn't the case for all files.
bgerold
in reply to: bgerold
I got around this problem by creating new layouts individually. Befor I set up my layouts by duplicating and those duplicated layouts didn' t shop up in my publish dialog box...
maxim_k
The same issue (sometimes) here, and the same workaround. Looks like a defect in AC for Mac. It is interesting also, that if I open such file with "corrupted" layouts in AC 2012 for Windows and reassign Page setups for each of "corrupted" layouts without even recreating them - then in AC for Mac everything works well with adding these layouts to batch publish.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Yes, I'm achieving the same problem - it gets worse, I select a couple of sample drawings from the icon with the 4 squares at the mid-right bottom, and then right click to "print", they show up in the Publish dialogue, but when it comes to printing, it will simply abort the printing process. What is wrong here? Autodesk please solve this immediately, I have hundreds of drawings to publish and I cannot spend the time sitting by the computer printing each individual drawing and then compiling them.
David_Stacey
Let's hope Autodesk is listening and has fixed this in SP1 (now in beta)
Leaf.chai
Hi all,
Thanks for reproting this issue to Autodesk.
There is a defect and I will keep on tracking with it.
Leaf
Leaf Chai
AutoCAD QA Analyst
”Boost
