We have a problem that cant work out what the issue is with ACAD LT for Mac 2015.
When using project manager on the network, substantial lag is experienced on the networked macs.
We three imacs in office, have two machines running ACADLT for MAc 2015, and one running ACAD 2011 for windows through parallels.
One mac used as server, and the .dst file lives there. other machines are wirelessly networked (strong network with no wireless problems)
- On this mac machine, there is no discerable lag in paperspace performance when using a .dst
- On the windows machine, there is no discernable lag in paperspace performance when using the same .dst
- On either of the other mac machines when using ACAD LT for Mac 2015 there is this wierd lag, to the extent as to make it not usable, not just irritatingly slow.
(the lag shows itself in whether drawing an element, moving a viewport, or adding in text to attributable callouts - for example you type text, then wait, wait and then it shows up - so the commands are getting through but somethings screwing it up on the way!)
Attmepted fixes without result;
- reinstalled the application
- reinstalled the operating system
Have trialed creating a local .dst file on the machines with lag, and no lag when using a .dst locally.
So isnt project manager meant for collaboration, it would appear from our process or elimination the problem could be how the macs talk to each in project manager.
Help, is there something we are doing wrong?
I have several questions.
1. OS version of Mac of two machines
2. Which type of network environment do you use. Is it AFP(can be used to access Mac only)
or SMB(can useD for Mac to Access both Mac and Windows)?
3. What is Server.app's version?
And for a test, just create a simple project which has 2~3 drawing files and see if you have the same result.
thanks for looking into this annoyance. here is my answers:
1. all machines run OSX 10.9.5 mavericks latest install
2. we use afp network. smb is also enabled as we have one machine running parallels with autocad 2011, but not generally in use
3. server app 3.3.2 - v4 does not have the required functionality for our office
4. we have done various tests with smaller number of files in a project. no difference to performance there. on testing with different number of viewports on a paperspace page, this does affect performance lag, while even with one, it is unusable, noticable slower as more on page.
particular to note is that this problem does not occur when using the same .dst on the network on the windows machine (running through parallels), only on the LT for Mac
at present we are unable to use the collaboration facilities promised by project and we used previously with sheet sets due to this problem. this is a significant drag on our business when we thought we were upgrading to the latest and best...
Hey, could you try this?
I guess there should be some messages about the network transfer info.
Hello, we have a similar problem.
We are a small office of 5 imacs, 3 running AutoCAD LT 2013, connected to a Synology DS211+ running DSM 5.1
We used to connect to the Synology using AFP but we were unable to add layouts to the Batch Print or Project Manager so we switched to using SMB.
The worst affected machine is running AutoCAD LT 2013 G.55.M.305 on OS X Yosemite 10.10.3
Similarly to above, use of the Project Manager slows AutoCAD to such an extent that it is unusable.
This is a short extract from the Console as AutoCAD starts up and a drawing is opened from the project manager:
01/05/2015 09:40:29.680 AutoCAD LT 2013[473]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.3 instead of 10.10.3. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
01/05/2015 09:40:29.680 AutoCAD LT 2013[473]: 0 CarbonCore 0x00007fff9c1a02b7 ___Gestalt_SystemVersion_block_invoke + 113
01/05/2015 09:40:29.680 AutoCAD LT 2013[473]: 1 libdispatch.dylib 0x00007fff8dcbec13 _dispatch_client_callout + 8
01/05/2015 09:40:29.680 AutoCAD LT 2013[473]: 2 libdispatch.dylib 0x00007fff8dcbeb26 dispatch_once_f + 117
01/05/2015 09:40:29.680 AutoCAD LT 2013[473]: 3 CarbonCore 0x00007fff9c129456 _Gestalt_SystemVersion + 987
01/05/2015 09:40:29.680 AutoCAD LT 2013[473]: 4 CarbonCore 0x00007fff9c1286e3 Gestalt + 144
01/05/2015 09:40:29.680 AutoCAD LT 2013[473]: 5 QtCore 0x0000000107203f96 _Z15qt_error_stringi + 742
01/05/2015 09:40:29.680 AutoCAD LT 2013[473]: 6 ??? 0x00007fff67f6fceb 0x0 + 140734937627883
01/05/2015 09:40:35.822 FNPLicensingService[517]: Started - This service performs licensing functions on behalf of FlexNet enabled products.
01/05/2015 09:40:36.272 FlexNet Licensing Service[517]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.3 instead of 10.10.3. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
01/05/2015 09:40:36.272 FlexNet Licensing Service[517]: 0 CarbonCore 0x00007fff9c1a02b7 ___Gestalt_SystemVersion_block_invoke + 113
01/05/2015 09:40:36.273 FlexNet Licensing Service[517]: 1 libdispatch.dylib 0x00007fff8dcbec13 _dispatch_client_callout + 8
01/05/2015 09:40:36.273 FlexNet Licensing Service[517]: 2 libdispatch.dylib 0x00007fff8dcbeb26 dispatch_once_f + 117
01/05/2015 09:40:36.273 FlexNet Licensing Service[517]: 3 CarbonCore 0x00007fff9c129456 _Gestalt_SystemVersion + 987
01/05/2015 09:40:36.273 FlexNet Licensing Service[517]: 4 CarbonCore 0x00007fff9c1286e3 Gestalt + 144
01/05/2015 09:40:36.273 FlexNet Licensing Service[517]: 5 FNPLicensingService 0x0000000100016580 FNPLicensingService + 91520
01/05/2015 09:40:36.273 FlexNet Licensing Service[517]: 6 FNPLicensingService 0x0000000100015ea9 FNPLicensingService + 89769
01/05/2015 09:40:37.000 AutoCAD LT 2013[473]: dynamic_cast error 2: One or more of the following type_info's has hidden visibility. They should all have public visibility. N3OGS7Objects6ICloneE, N3OGS7Devices14OGSFileHandlerE, N3OGS7Objects18IOneTimeInitializeE.
01/05/2015 09:40:37.000 AutoCAD LT 2013[473]: dynamic_cast error 2: One or more of the following type_info's has hidden visibility. They should all have public visibility. N3OGS7Objects6ICloneE, N3OGS7Devices14OGSFileHandlerE, N3OGS7Objects11ARefCountedE.
01/05/2015 09:40:37.002 AutoCAD LT 2013[473]: *** -[NSAutoreleasePool drain]: This pool has already been released, do not drain it (double release).
01/05/2015 09:40:40.474 AutoCAD LT 2013[473]: Could not find image named ''.
01/05/2015 09:40:47.644 AutoCAD LT 2013[473]: CFURLGetFSRef was passed this URL which has no scheme (the URL may not work with other CFURL routines): /Applications/Autodesk/AutoCAD LT 2013/AutoCAD LT 2013.app/Contents/Plugins
01/05/2015 09:42:35.468 com.apple.xpc.launchd[1]: (com.apple.imfoundation.IMRemoteURLConnectionAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
01/05/2015 09:42:40.860 AutoCAD LT 2013[473]: [buttonClick] sender:[<AcWorkflowButton: 0x60800036ea00>] [AcOCRibbonItem] uid:[ID_RBN_CMDBTN_LINE] text:[Line] type:[0] command:[[MenuData] type:[19082912] command:[_line ] smallImage:[RCDATA_16_LINE]]
01/05/2015 09:45:36.810 SpotlightNetHelper[315]: [SLSUGGESTIONS] Location managed failed with error Error Domain=kCLErrorDomain Code=0 "The operation couldn’t be completed. (kCLErrorDomain error 0.)"
Yesterday, when trying to navigate the drawings the log filled with messages similar to the following:
30/04/2015 16:02:03.287 QuickLookSatellite[2990]: /Volumes/Shared/0_000_Studio_Architettura_Projects/1_021_Gresley Road/Z_Drawings/06_Details/021_Detail_Section_B.dwg
30/04/2015 16:02:08.825 AutoCAD LT 2013[2908]: *** -[NSAutoreleasePool drain]: This pool has already been released, do not drain it (double release).
30/04/2015 16:02:08.000 kernel[0]: FindFileRef: pid not matching
30/04/2015 16:02:09.000 kernel[0]: FindFileRef: pid not matching
30/04/2015 16:02:10.000 kernel[0]: FindFileRef: pid not matching
30/04/2015 16:02:11.000 kernel[0]: FindFileRef: pid not matching
30/04/2015 16:02:12.000 kernel[0]: FindFileRef: pid not matching
30/04/2015 16:02:13.000 kernel[0]: FindFileRef: pid not matching
30/04/2015 16:02:14.000 kernel[0]: FindFileRef: pid not matching
30/04/2015 16:02:24.201 QuickLookSatellite[2990]: /Volumes/Shared/0_000_Studio_Architettura_Projects/1_021_Gresley Road/Z_Drawings/06_Details/ss/021_Detail_Section_B.dwg
30/04/2015 16:02:36.524 QuickLookSatellite[2990]: /Volumes/Shared/0_000_Studio_Architettura_Projects/1_021_Gresley Road/Z_Drawings/06_Details/021_Detail_Section_B_new.dwg
30/04/2015 16:02:49.093 AutoCAD LT 2013[2908]: *** -[NSAutoreleasePool drain]: This pool has already been released, do not drain it (double release).
30/04/2015 16:02:49.000 kernel[0]: FindFileRef: pid not matching
30/04/2015 16:02:50.000 kernel[0]: FindFileRef: pid not matching
30/04/2015 16:02:51.000 kernel[0]: FindFileRef: pid not matching
30/04/2015 16:02:56.000 kernel[0]: FindFileRef: pid not matching
30/04/2015 16:02:57.000 kernel[0]: FindFileRef: pid not matching
30/04/2015 16:03:32.000 kernel[0]: FindFileRef: pid not matching
30/04/2015 16:03:32.780 QuickLookSatellite[2990]: /Volumes/Shared/0_000_Studio_Architettura_Projects/1_021_Gresley Road/Z_Drawings/06_Details/021_Detail_Section_B.dwg
If there is any further information that I can provide please let me know because at the moment the collaborative tools are essentially unusable.
Many thanks,
Nick
Just had a really good example of the delay, navigating the drawing essentially impossible, even closing the Project Manager takes multiple attempts, sometimes when it even appears to re-open automatically after it has closed. The console log shows:
01/05/2015 10:17:50.152 AutoCAD LT 2013[473]: *** -[NSAutoreleasePool drain]: This pool has already been released, do not drain it (double release).
01/05/2015 10:17:51.109 AutoCAD LT 2013[473]: assertion failed: 14D136: libxpc.dylib + 62495 [D35D0DB2-D7BD-3BE4-8378-062BFE545E1D]: 0x89
01/05/2015 10:18:02.313 com.apple.xpc.launchd[1]: (com.apple.quicklook[576]) Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
01/05/2015 10:18:02.607 QuickLookSatellite[577]: /Volumes/Shared/0_000_Studio_Architettura_Projects/1_008_Sutherland Avenue/Z_Drawings/in progress/01_CONTENT/100-plans/102_LowerGround_Floor_Square.dwg
01/05/2015 10:18:02.612 QuickLookSatellite[577]: CGContextResetCTM: invalid context 0x0. This is a serious error. This application, or a library it uses, is using an invalid context and is thereby contributing to an overall degradation of system stability and reliability. This notice is a courtesy: please fix this problem. It will become a fatal error in an upcoming update.
01/05/2015 10:18:02.664 QuickLookSatellite[577]: CGContextConcatCTM: invalid context 0x0. This is a serious error. This application, or a library it uses, is using an invalid context and is thereby contributing to an overall degradation of system stability and reliability. This notice is a courtesy: please fix this problem. It will become a fatal error in an upcoming update.
01/05/2015 10:18:02.664 QuickLookSatellite[577]: CGSConnectionByID: 0 is not a valid connection ID.
01/05/2015 10:18:02.664 QuickLookSatellite[577]: Invalid Connection ID 0
01/05/2015 10:18:04.843 WindowServer[136]: disable_update_timeout: UI updates were forcibly disabled by application "AutoCAD LT 2013" for over 1.00 seconds. Server has re-enabled them.
01/05/2015 10:18:05.416 WindowServer[136]: common_reenable_update: UI updates were finally reenabled by application "AutoCAD LT 2013" after 1.57 seconds (server forcibly re-enabled them after 1.00 seconds)
A second issue, which may be related, is that while working on a drawing it will suddenly close without warning. AutoCAD doesn't 'crash' exactly, the menus stay at the top of the screen and drop down but do not offer any usable options. The only way out is to Force Quit. Restarting gives the option of recovering files but the files recovered do not include the last few minutes of edits.
Again, the log from the point where it crashed to restarted is as follows:
01/05/2015 11:03:32.337 Console[430]: Marker - 1 May 2015 11:03:32
01/05/2015 11:04:48.142 com.apple.iCloudHelper[629]: objc[629]: Class FALogging is implemented in both /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle and /System/Library/PrivateFrameworks/FamilyNotification.framework/Versions/A/FamilyNotification. One of the two will be used. Which one is undefined.
01/05/2015 11:04:48.148 com.apple.xpc.launchd[1]: (com.apple.imfoundation.IMRemoteURLConnectionAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
01/05/2015 11:08:43.153 spindump[384]: Got xpc error message in libspindump client connection: Connection invalid
01/05/2015 11:08:43.288 com.apple.xpc.launchd[1]: (com.autodesk.AutoCAD_LT_2013.43768[473]) Service exited due to signal: Killed: 9
01/05/2015 11:09:23.889 AutoCAD LT 2013[630]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.3 instead of 10.10.3. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
01/05/2015 11:09:23.889 AutoCAD LT 2013[630]: 0 CarbonCore 0x00007fff9c1a02b7 ___Gestalt_SystemVersion_block_invoke + 113
01/05/2015 11:09:23.889 AutoCAD LT 2013[630]: 1 libdispatch.dylib 0x00007fff8dcbec13 _dispatch_client_callout + 8
01/05/2015 11:09:23.889 AutoCAD LT 2013[630]: 2 libdispatch.dylib 0x00007fff8dcbeb26 dispatch_once_f + 117
01/05/2015 11:09:23.889 AutoCAD LT 2013[630]: 3 CarbonCore 0x00007fff9c129456 _Gestalt_SystemVersion + 987
01/05/2015 11:09:23.889 AutoCAD LT 2013[630]: 4 CarbonCore 0x00007fff9c1286e3 Gestalt + 144
01/05/2015 11:09:23.889 AutoCAD LT 2013[630]: 5 QtCore 0x0000000107203f96 _Z15qt_error_stringi + 742
01/05/2015 11:09:23.889 AutoCAD LT 2013[630]: 6 ??? 0x00007fff64f11ceb 0x0 + 140734886911211
01/05/2015 11:09:25.535 FNPLicensingService[672]: Started - This service performs licensing functions on behalf of FlexNet enabled products.
01/05/2015 11:09:25.793 FlexNet Licensing Service[672]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.3 instead of 10.10.3. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
01/05/2015 11:09:25.793 FlexNet Licensing Service[672]: 0 CarbonCore 0x00007fff9c1a02b7 ___Gestalt_SystemVersion_block_invoke + 113
01/05/2015 11:09:25.794 FlexNet Licensing Service[672]: 1 libdispatch.dylib 0x00007fff8dcbec13 _dispatch_client_callout + 8
01/05/2015 11:09:25.794 FlexNet Licensing Service[672]: 2 libdispatch.dylib 0x00007fff8dcbeb26 dispatch_once_f + 117
01/05/2015 11:09:25.794 FlexNet Licensing Service[672]: 3 CarbonCore 0x00007fff9c129456 _Gestalt_SystemVersion + 987
01/05/2015 11:09:25.794 FlexNet Licensing Service[672]: 4 CarbonCore 0x00007fff9c1286e3 Gestalt + 144
01/05/2015 11:09:25.794 FlexNet Licensing Service[672]: 5 FNPLicensingService 0x0000000100016580 FNPLicensingService + 91520
01/05/2015 11:09:25.794 FlexNet Licensing Service[672]: 6 FNPLicensingService 0x0000000100015ea9 FNPLicensingService + 89769
01/05/2015 11:09:26.300 AutoCAD LT 2013[630]: dynamic_cast error 2: One or more of the following type_info's has hidden visibility. They should all have public visibility. N3OGS7Objects6ICloneE, N3OGS7Devices14OGSFileHandlerE, N3OGS7Objects18IOneTimeInitializeE.
01/05/2015 11:09:26.300 AutoCAD LT 2013[630]: dynamic_cast error 2: One or more of the following type_info's has hidden visibility. They should all have public visibility. N3OGS7Objects6ICloneE, N3OGS7Devices14OGSFileHandlerE, N3OGS7Objects11ARefCountedE.
01/05/2015 11:09:26.300 AutoCAD LT 2013[630]: *** -[NSAutoreleasePool drain]: This pool has already been released, do not drain it (double release).
01/05/2015 11:09:29.517 AutoCAD LT 2013[630]: Could not find image named ''.
01/05/2015 11:09:32.786 AutoCAD LT 2013[630]: -_continuousScroll is deprecated for NSScrollWheel. Please use -hasPreciseScrollingDeltas.
01/05/2015 11:09:32.786 AutoCAD LT 2013[630]: -deviceDeltaX is deprecated for NSScrollWheel. Please use -scrollingDeltaX.
01/05/2015 11:09:32.786 AutoCAD LT 2013[630]: -deviceDeltaY is deprecated for NSScrollWheel. Please use -scrollingDeltaY.
Hi @softwareC3HSK,
Do you have specific error messages that you are receiving?
Can you provide more information? AutoCAD release? 2015, 2016? EL Captain?
Hi @Emmsleys,
Yes, we are using AutoCAD for Mac 2016. El Capitan 10.11.16.
We aren't receiving error messages. But we are experiencing substantial lag when using the project manager on the network.
When using a .dst file and layouts that are located on a local folder, we do not experience any problems. Yet, when we use a .dst and the corresponding layouts live on the server, then we basically cannot use it. It takes about 1 min to even select a layout on the project manager.
Hi @softwareC3HSK,
I may need to log a defect for this specific issue.
I will go ahead and attempt to recreate the issue again and I'll let you know what the defect number is.
Please let me know if you experience any other issues when working from the files on the network.
