Good afternoon,
I have recently installed Autocad 2014, and i'm facing a problem that is: when i'm doing a line, a retangle, an offset, everything when i have to put measures, and if I want to define that the measure of the line is 3,14 m, when i put the "." it transform the "3" in the x measure and the "14" in the Y measure and expects me to put another measure for Z. My work need to be precise so I have to use decimal measures. Can this be solved some way? If I import the workspace and definitions from Autocad 2012 (when this never happened) can this work?
Thank you very much for your help.
Thank you for your quick answer.
In my Mac i have a textpad and a numeric pad. I normally use the numeric to insert the values and now in ACA 2014 I can't use the dot in the numeric pad (when I used to work this way in 2012). It only work as decimal numbers if i use the dot it in the text pad. If I use the comma in the text pad it happens the same and starts using coordinates.
It is easier to use the numbers and the dot in the numeric pad than use the numbers in the numeric and the dot in teh text pad. Can this be solved?
Thank you.
