Hi everyone,
I'm having problem saving my dwg file as pdf, I explain:
I have autocad2014 on a Mac OS X, when I go to print and do all the edit page setup for an A1 page,
everything seems fine but when I try to save as pdf.. nothing happens.. I created a new dwg file
but nothing it doesn't save it.. I know that it works because I used it just some months ago,
I tryed the export as solution but it cuts half of the page even if i set it up..
I don't know what to do anymore and this is driving me crazy because tomorrow I have the deadline..
So please if anyone can help me i'd very glad.
Welcome to the Autodesk Forums!
This could be a problem of paper size you are using.
Try to create Custom Paper size with the same parameters as A1 paper size, use page setup to assign this Custom Paper size to page setup you are using to export as PDF.
You can also try to save as PDF from Preview after you will create custom paper size and assign it to Page setup, but before you click on Preview button - check that your custom paper size (you can give it some special name) is in place in "Paper size" list in Print dialog:
Maxim
