hi everybody every time i try to print from the model by window the image in the pdf is a little bit shifted from the one i chose in my selection...is there anything i can do?
Have you tried "Center on page" option in Page Setup dialog?
Maxim
thank you for the help but i can't do that...i explain myself, there are a lot of command i can't use on autocad 2013 for mac such as pagesetup, plotstyle because when i do everything is blocked and when i click sounds like "tung,tung" Is there another way to do that since now i'm printing in A1 and cutting them after. What is my problem with those commands, is there a common problem?since i had the same problem in autocad 2012 for mac..is there anything i can do,
Thanks for the help.
Have you tried to "Reset Application Options..." from Application tab of AutoCAD Preferences?
Or at least to reinstall AutoCAD (don't forget to uncheck "Leave my settings" in "Remove AutoCAD" dialog.
Maxim
This issue was fixed in AutoCAD 2013 for Mac SP1 and AutoCAD 2012 for Mac SP3. You can click menu AutoCAD 2013 > check for updates to install SP1. Then, you should not have this issue.
Wei
