AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
printing from the model
6 REPLIES 6
282 Views, 6 Replies
hi everybody every time i try to print from the model by window the image in the pdf is a little bit shifted from the one i chose in my selection...is there anything i can do?
6 REPLIES 6
maxim_k
Have you tried "Center on page" option in Page Setup dialog?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
thank you for the help but i can't do that...i explain myself, there are a lot of command i can't use on autocad 2013 for mac such as pagesetup, plotstyle because when i do everything is blocked and when i click sounds like "tung,tung"  Is there another way to do that since now i'm printing in A1 and cutting them after. What is my problem with those commands, is there a common problem?since i had the same problem in autocad 2012 for mac..is there anything i can do,
Thanks for the help.
maxim_k
Have you tried to "Reset Application Options..." from Application tab of AutoCAD Preferences?
Or at least to reinstall AutoCAD (don't forget to uncheck "Leave my settings" in "Remove AutoCAD" dialog.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
thanks for the reply, i'm not sure i understood what you just sad..could you please explain that to me again?
ups i'm sorry wrong post i didn't understand the other one about the ctb
wei503
This issue was fixed in AutoCAD 2013 for Mac SP1 and AutoCAD 2012 for Mac SP3. You can click menu AutoCAD 2013 > check for updates to install SP1. Then, you should not have this issue.
Wei
Wei Ma
AutoCAD for Mac QA Manager
”Boost
